Are the piston pins pressed in or are the full floating? In other words, can the piston be removed from the connecting rod without taking the connecting rod out of the case?
John
there are circlips on both side of the wrist pin you need to remove one of them and pull the wrist pin out. you do not need to remove the con rod
