1 - 11 of 11 Posts
I removed the reflectors today. At the rear, the reflectors are held on by brackets that contain 3 captured nuts, which receive the bolts that hold both the rear shelf and the tailight to the bike. This necessitated taking a dremel and cutting the reflector off, and then grinding this bracket smooth. I painted them for good measure. Up front, the left side is just the bracket for the reflector, which comes off with 1 bolt, but on the right side the same bracket also holds a clamp for what appears to be part of the ABS line. Couldn't think of anything to do with this one, but I removed it anyway. The line appears to be OK without the clamp. Anyone have a better idea for this one?
I took mine of too. The right fron one made me uncomfortable without the ABS lineclamp, so I took the original bracket and cut it off below the clamp and repainted it.
Gentlemen, function before style. What are you replacing them with? I am sure you found something awesome. I am also positive you didn't just remove them and make the motorcycle harder to see.
Ted G,
Took them off because they are ugly.
buffgunner,
I suppose I can cut one more bracket.
Is ugly so important when some dumb SOB runs into your bike because he couldn't see it?
Benn riding continuously since 1964, and I always pull the reflectors. No one has run into me yet.
They're a US requirement only. If they are all that keep me from being broadsided, then I screwed up badly. Also, my riding jacket has reflective on it.
buffgunner,
We are on the same page. Going to modify the front bracket now (G).
Done!
Ted when you have a black bike, removing the ugly reflectors is not going to change anything regarding safety.....
To each their own, but I am a firm believer in being seen. Reflectors are light weight and can be seen at night. They are still on my 10 and C14. I think square ones would look better. Motorcycling is a game of survival, and one needs all the ammunition you can get. If we need to change anything, we need to get a real horn.
1 - 11 of 11 Posts
