I appreciate all you guys on here that have helped me in the past on questions I had! I have a 91 zx11 and when it runs for awhile it seems to run a little hot, and when I come to a stop, the 2 oil and gas lights comes on while I am idling and then when I start going they go off. Any suggestions???
look on the bottom of the engine, beside the drain plug there is a pressure relief switch, it will have a black wire and a black rubber boot on the switch, pull the switch off and make sure it is not rusted out under the boot if it is clean it and put it back on. I removed the boot all together. check out this post I had the same problem a month ago.
http://www.zxforums.com/forums/showthread.php?t=3834
thanx for the info, but I am not the greatest when it comes to bikes. Do I have to take off any of the fairings to get to this part? which side is it on? or is it directly underneath the bike. Sorry for being such a tard. I need like an exact location lol. Once I get to it, I can fix it. Thnx again
