Hi everyone I am new to the zx11 just bought one last week and wondering if a zx11d front end will fit on a zx11c if so is there any benefit to this swap? I am thinking about the whole front end including brakes and triple tree. The ones on right now are slightly bent. Also Stainless steel brake lines were can I get them for not much money? Thanks for any info.
The main difference between D's and C's front end is brake discs diameter (C= 310 mm, D= 320 mm). Beside this, it's the same technology and same adjustability (preload and rebound damping). Not a single part exchange though but as an assembly, it will fit. You will also need to use D's front fender.
As for brake lines, you can find them anywhere.
