I recently changed my stator cover and while removing the cover one of the gears had popped out too... now I am getting no cranking occasionally... could this be due to the pin for that gear being in backwards or is it really the starter that is going bad? I have all electrical and when it does crank it runs good. Help!!!!
It could be the starter going bad, but it would seem, being that it started right after you worked on it, that something was not installed exactly right. Pull the cover & check everything out. You may be causing more damage each time you start & run the engine now. Better to be safe than sorry.
