I've got a 1991 ZX-11 that continually fouls the spark plugs. I've installed a set of used carbs and I'm beginning to think that they have a jet kit installed. I have a Vance & Hines Supersport pipe I plan on installing soon... should that clear it up? Is there a hotter plug I could purchase? :headscratch
try the pipe, maybe it will match seeing as there is so few options, you might have got a carb jetted for that pipe, but that's kinda iffy. hotter plugs? if it's running to rich, a different plug won't make a difference. anyways, good luck, hope you don't have to blow some on a new jet kit! carbs are a bitch! next bike i'm getting WILL BE FUEL INJECTED!!!
