I have a 03 636 with a GP style exhaust and a K&N filter
I have tried all the maps from the PC web site but none of them work to well.
Is there any chance someone has a map that will work ok with this exhaust?
Thanks for any help
Si
Its kind of rough coming out of corners, just when you start to roll the throttle on. A sort of burble sound but not a bogging sound, then it picks up and goes smooth by 1/3 throttle.
hope this description helps
;) Not as much as I was hoping it would. Sounds like you might be a little lean on the low end. Have you tried to find a shop that'll make a custom map for you? Rather then farting about with someone else's map that cannot be anything besides, "close." You could have someone build an exact map for you. It'll be a little expensive, but I think it'd be worth it.
yeah, i will get i dyno tuned eventually. i have a lack of money at the mo cos i just rebuilt the bike.
I was just looking for something to patch the problem temporarily or use some ones map which is closer than what i got
