1 - 15 of 15 Posts
Very little left at this point. Thanks for all your interest!
Four bungee clips (two on each side on the rear fairings), Motor mounts and bolts, any and all bolts you have after disassembly.
And the six chrome caps on the frame (three each side).
And maybe the tank, I need to see a pic of the backside and the bottom. I think the CA tank has a fuel return, and that's what I'm looking for.
47338 is the zip
$80+shipping for both rear cowls. That includes 2 of those bungee clips and both rear turn signals.
$200+shipping for the frame with title. That includes the lower subframe, engine mounts, engine mounting bolts and 6 chrome plastic caps.
I'm not currently offering to ship the tank. It still has some gas in it and I'm keeping the cap. If I can't sell the tank locally, I'll drain it, rinse it, dry it and then offer to ship it.
Discussion Starter · #6 · (Edited)
@steell:
I have 2 bungee clips, the lower front engine mounts with bolts, all engine mounting bolts that fit in a USPS medium flat-rate box, 6 plastic chrome caps: $50 shipped
$60 shipped if you need the longer bolts that will require a bigger box
Other than the engine mounting bolts, which bolts from disassembly are you most interested in? Most bodywork bolts went with related body parts, some engine bolts have gone with related engine parts, some were missing.
Discussion Starter · #7 · (Edited)
@ C 4:
Right rear taillight, $25 shipped, the lens has a minor crack.
I bought a 96 D model with no motor, none of the plastic bolted down, and the gas tank not bolted down, and no bolts. Bolts for the oil cooler and radiator are missing also.
And the shifter is broke.
That's why I'm looking for bolts.
I will add as many of the bolts you need as I can for the prices quotes above.
I should have tank bolts, radiator bolts, oil cooler bolts.
I might have some of the body mounting bolts, but most are gone.
The shift pedal and left rearset have been sold if that's what you're referring to.
Discussion Starter · #13 ·
@ steell & mermalion:
Your parts are on the way!
Discussion Starter · #15 ·
That's long gone, sorry.
1 - 15 of 15 Posts
