1 - 16 of 16 Posts
This is a new part out of a 05 zx636 that has 73xx miles. the list is as follows:
Frame with COD cert. $200 (has a very small dent but is straight as the factory sends it.
Frame with good title $600
Motor kit w/ just over 7kmiles $1300
subframe $50
Rear wheel $120
front wheel $150 (has slight wobble)
Rear suspension conversion (swingarm, linkage, rearcaliper/line/hangar, shock, axle) $200
front driver seat $20
Rear passenger seat $40
left and right rear sets $40 for left and $60 for right)
tank with cover $100 (matte black but was painted professionally) SOLD
Tank (blue, and has 2 small dents) $50
Forks with upper and lower tripple $200 (good seals)
gauges with 73xk miles $100 SOLD
clip ons $40
front brake calipers w/ new pads $40
Front master cylinder $50 (includes resi, lever and master)
ram air tube $60
upper fairing stay $30
left lower fairings $50
right lower fairing $70
Mid fairings $70 (OEM green) or i have some scuffed up ones( make good painters. No cracks) $50
headlight w good tabs $150
CHain w/ 600 miles $30
lock set (includes gas cap, ignition, trunk lock) $100
trim plastic under seat $20 each side.
dash trim pieces $25 each or $40 for both. SOLD
stock mid pipe $20
stock exhaust $30
passenger rearsets $30
front fender $50 (magma red)
tail light $30
stock grips $10
hand controls/switches $15 each side
stock bar ends $15
undertray/trunk plastics $15
plastic panel under headlight $15
fuel pump $40
all OEM fairing bolts from bike $30 (over 30 of them)
throttle asym (cables, tube, housing) $30
rear OEM blinkers $20 for both
ECU $150
wire harness $100
stock header $20
how much for a complete set of fairings?
and can i get some pics of them?
thanks
oh and ill take the trunk plastics
VP Whoring
Right dash trim condition ?
Subframe for 50? That spoken for yet?
Frame
I'm new to bikes so I have no idea what the part is called, It is the frame where the rear pedal brake is connected. I guess I was braking to hard and the frame broke but not the pedal. Let me know if you have it.
Specifically which bolts are you selling off the bike fairings isnt enough information.
1 - 16 of 16 Posts
