hi, new to the site, i am running a 95-96 zx6r-f model and have been looking at boring out the capacity of the engine to around 660cc, has anyone done a similar modification and if so which pistons were used? have found a 617cc kit off the shelf with all gaskets etc. but am looking to go bigger, can get all bore work done but am having trouble sourcing a piston kit, all help appreciated thanks, Alan
Alan, you are limited by the bore of the barrel. If you want more bore, then bore the barrels and re-sleeve for the bigger pistons. Call all the piston manufacturers and ask for your model's largest capacity pistons they make.
If L.A. Sleeve is still in business, buy the bore inserts and have at it.
