1 - 13 of 13 Posts
I have posted this on an older post but I thought I might get some more responses if I started a new thread.
I bought a local 1992 ZX11. Changed the oil , fluids etc. like you would do with any normal bike that you bought. Went for a ride all was good. Actually went on several rides with no issue.
However, the last ride a went on, everything seems good. I park the bike and the next morning I come out to a puddle of oil!!! I would say 1/4 of a quart? Enough that I am using a ton of paper towels to clean it up
As a suggest by someone on the forum
- I decrease everything.
- Wipe everything down
- Use baby powder all over the engine
- Add some oil back in
I then go for a 10 minute ride. While I am stopped at stop signs etc. I look down... no oil.
I get home, put the bike on the center stand within 5 minutes. I start to smell burning oil and there is oil dripping on the exhaust (I have a Muyzzy 4 into 1 if that matters). There is not a stream of oil but a steady drip... but I cannot for the life of me tell where it is coming from !!! None of the baby powder shows any signs of oil from any of the banjo fittings. I took the clutch slave unit off so I can look at the sprocket... no oil.
The best way to describe it , it seems to be leaking from something above and behind the water pump. I cam back and had another decent size puddle.
Here is the other thing.... eventually I clean up all the oil, put a white towel down and EVENTUALLY there is no drip. If I look at the oil level , I can see it is below the fill line but maybe 1/4 of a quart of oil takes it back
to a good level. It doesn't seem to leak again unless I start it and get it warm.
I took a video of the drip ... I am hoping this link works.
Would love to know your thoughts !!!
https://photos.app.goo.gl/XrZh337V8UVGcXqaA
Todd
If the oil filter 'O' ring is not sealing the oil can run quite a distance before it drips down. This bike also has two sump plugs, check both.
Maybe I going to ask a dumb question... But all the videos of Zx11's have the filter inside the oil pan underneath... How would oil be dripping from the filter???!!
Shift shaft seal is the most common left-side oil leak and is sometimes difficult to pinpoint without removing the drive sprocket cover.
Discussion Starter #6
I found the left side leak !!!
Wow... after multiple degreasing.... cleaning etc.... I final dug in an took the water pump off.... AND .... There is a small hoel on the under side of the water pump
oil is leaking out of it. (attached picture)
Why would oil be leaking out of this hole?
Does that mean my water pump is bad?
Thanks for all the help so far
Todd
That’s the weep hole that coolant will stream out of when the pump goes bad. There really shouldn’t be oil coming out of that; are you sure the oil isn’t coming past that o-ring on the engine side and maybe dripping towards that hole?
The weep hole will leak coolant to indicate that the internal seal is gone. If you are getting oil, I would bet it is the o-ring on the pump into the case is where it is leaking. Since you have the pump out, I would replace it anyways just to be sure. If your leak goes away, you know where it was. If not, you have eliminated one possibility.
Discussion Starter #10
oil leak saga continues ... but getting close !!
Can't thank you guys enough for all the help !! I got a water pump from a friend and I got it installed... well ALMOST... pretty straight forward installation...
My only problem is the cover for the water pump has a gasket. It fit perfectly in the groove. However.... strangest thing. It shifted out of the groove and now I can get it to align correctly !!!
if I didn't know any better I would think it was the wrong gasket seal!! Has anyone ever encountered this? Do I need to heat this up or something to "shrink it back to fit??!!"
Picture attached
Thanks
Todd
Did you clean it with gasoline? It has swollen maybe due to some contact with solvent. Go to the local shop and buy some 'O' ring material, some super glue to join it and make another if you cant buy the correct one.
After ur oring swells u can coat it in grease and let it sit for a few minutes maybe an hour and itll shrink down a bit. We use the bel-ray waterproof stuff at my dealership. Works on rubber quite well.
Discussion Starter #13
BTW .... Thanks for all the help... Got this totally fixed !!!
The engine is now out ... and undergoing refresh !!
Todd
1 - 13 of 13 Posts
