I have a question with similar problem.
I own a 2000 600zxr and the engine was pooched, when I got it.
I picked up a engine that appears to be a earlier one.
My problem is the same in the sense that
mine is a 2000 and has the cooler built into the spout for the oil filter. Then to the rad.
The engine i will be using is the older style with a separate rad.
Can I remove the system from my 2000 600 engine?
Then put it on my older model?
Thanks in advance
