Hey guys i am having some trouble with my 2006 zx-6r, i recently replaced the stator and battery on it. But the battery is still not getting a charge. I took a multimeter and tested the stator and i can confirm that it is working. I also took the battery up to advance auto parts today and the battery is good.
The only other thing i know to check would be the rectifier regulator, would that keep the stator from charging the battery? i really would like to avoid taking it into the shop if its at all possible but i am running out of options.
My 636 has no other electrical add-ons.
Thanks in advance for your help
· Premium Member
When you say you've tested the starter do you mean the altenator? If no then this would be your first point of call.
Check that the altenator is putting out a charge.
