Replaced the battery it was 5 yrs old and was due. Bike ran fine before changing just had trouble starting the last time I rode. Put the new battery in and it turns over fine just won’t start. I’m a little lost. Do these require a fully charged battery to start? I put it on the tender just a minute ago. Is there anything I could have done swapping the battery to cause this?
Discussion Starter #2
Figured it out. The wire from the power commander wasn’t grounded. Thanks for the help. I have to say this sight is pretty dead when it comes to helping out a fellow rider. I own a vmax also and they are incredible when I have questions or need help.
Sorry but never had any advise based on the info. Usually if you change something and it won’t start, go back and check everything you did. Never saw a mention of a PC so that would be tough to advise.
Glad you figured it out.
Discussion Starter #4
Thanks. Someone must have used a bad connector because I never saw it connected to the negative terminal
