I have a 2006 zx6r it sat in the rain one night and I haven’t had spark since I put new plugs in it tested the coils swapped the computer tested the kill switch put a new ignition in it did the stator did the pickup coil did the fuel pump swapped the battery and nothing is working also when I try to start it the FI light flashes NEED HELP it’s been 8 months
Hello and welcome!
Does the engine try to turn over, or is there just no response at all when you push the button?
If there is no response at all, then it could be the clutch lever switch or the kick stand switch.
Did you ever get this sorted out? I would start by checking fuses, I know it sounds simplistic but start with the basics and go from there. After that I would see if the comp has power, and make sure it's the full 12v. Did you ever try to see what the FI light is?
