1 - 9 of 9 Posts
Hello
my 2009 NINJA 250R
has an exhaust and air filter slot in pods
i have been told they are usless without
Power Commander
And i was thinking of changing to a smaller sprocket
(if i do will i have the get a bigger rear sprocket??)
With all these mods what will i get 0-60
if a standard ninja 250 does 7.5 seconds
as all im intrested in is 0-60
as i dont want a bigger bike im happy with this, just want to improve acceleration =) Thankyou
Welcome to the forums! Pics? If you want more acceleration, get a bigger rear sprocket
The 250R's stock gearing is 14/45. Replace the rear with a 50 and you'll notice quite a large difference. You'll add about 1k RPM to any given speed, though, which makes highway speeds very uncomfortable with vibrations / noise.
Try launching at 4-5k RPM and shifting between 8.5-10K RPM. Standard mapping sees peak torque at 9.5-10K.
Pod filters aren't really worth the hassle on a sportbike, and with a custom map + PC you'll see an increase of maybe 1.5-2HP. The bike comes on the lean side from the factory.
The little Ninjas are already lightweight and compact. You'll be throwing a lot of money at it before you notice any difference on the street.
Discussion Starter #5
Thankyou guys, so i will still get exhaust and power commander
as i already brought it
but with the front sprocket leave it at 14T and get a rear sprocket at 50T?
sound a bit high
as i will only be using for street and little carriageways i'm not bothered about top end
but how much will it knock off 10mph ??
I had no idea the 09 came in an EFI version until this post.
I know the US version of the 250r was carb'd throughout it's lifetime
Discussion Starter #8
Yeah, Uk Ninjas are FI so will a power commander help?
and if ninja 250 is 7.5 standard
if i mod it would i get 6.5? as i only way 145 pounds =)
Sprocket gearing change, power commander, aftermarket exhaust will provide you with benefits. I would also look into lightening the bike as well
1 - 9 of 9 Posts
