i may be buying a 1992 zxr 750, i was wondering, does anyone know what insurance group it is in. also any tips on what to look for, such as common faults to look for, any help would be appreciated. regards alan
Bodywork is VERY hard to come by for this bike. The better shape it's in the better off you are. If he has spares in good shape take them with you.
The clutch slave cylinder is prone to leaking if the seal is worn out. Not a hard fix, just time consuming.
If the ignition switch wiring is corroded they can be a pain to start.
They can vapor lock if the fuel lines are not insulated in some way( the factory never did this).
There are no real faults (such as prone to engine failures,etc.) with the bikes, just age issues for the most part.
