my girlfriend has a 09 250 that just started having troubles with the fuel level gauge and dies if you try to give it more than 1/3 throttle. i can sometimes hear the fuel pump kick on but not stay on at all times.. if i shake the bike and cycle the key the fuel gauge works and the bike runs as it should. so i have a 2 part request, any assistance on the diag of what its doing(i believe the fuel pump or the power source to it is bad), and 2 does anyone have a pdf manual that i could have?
7777
I'd say you have something in the tank. You may want to drain it and inspect. I'll bet you something is down there. Pull the petcock and see if you get crap. There is a filter on the back side of the petcock that could be plugged.
