Hi everyone,
I'm a new zx9 rider. Managed to bag myself a 99 C2 stock ninja (red/black) that's in pretty good shape. I have a few issues I'd like you guy's opinion of.
I've read through the forums to find someone with the same problem but as of yet, no one has the same 'noises' as I have.*
Between dead stop and moving up to around 3500 rpm there's a rattle that sounds like something clicking against plastic. Kinda like a knocking noise. It increases in speed with the bike and sound like the front end (hard to tell with helmet on!). It doesn't make the noise when stationary. I'm advised to check my calipers..?*
I should mention the bike was bought at 30k miles and I'm led to believe it has mostly been driven only 3k a year in dry weather. It was pretty clean when I got it other than a shed-load of sludge that had collected in the front sprocket. There's no signs of wear in the metals and frame/swingarm.
I have the seemingly common 'jumping' of revs when holding steady throttle too. Am I right that a jet kit is the answer? If so I know where to source one but am unsure of the benefits (money's tight these days!). I don't care about extra hp, just a comfy ride.
Im curious about lowering the front end. If it increases stability in corners, as I've read, then I'm all for it. I ride mostly town roads (stop start) and sometimes 20miles of motorway 6 times a week so I do a lot of miles.
How much should I lower the forks through the clamps? Do I need an extra pair of hands to hold things so it doesn't fall apart on my concrete garage floor? :-/
I also want to repaint the fairing. Any tips for a complete newbie? Current fairing is stock black/red/purple from 99 C2. I'd like it black mostly with white and/or ninja green. Yum.*
Do the stickers peel off easy? Do I have to sandblast the old paint off the tank first? The panel stickers On the tank look lacquered..?
One last one.. I read someone changed the rear end of their zx9 to a zx6 tail. Does this involve cutting metal? If so I'm not that way inclined. But nice if not. And the 2001 zx9 front fairing fits 99?
Thanks
Rob
Thanks
Rob
