Just bought a 91 750cc thats been sitting in storage for a little over a year. What kind of maintenance should I do before taking the bike out?
Us Should Check The Wheel Bearings, Change The Oil, Check Your Coolant,and Spark Plugs (could B Fouled).then If You Didn't Drain The Tank Do That, Run Some Carb Cleaner That Mixes With The Gas. I Used Sea Foam After It Sat Last Winter In Indy. Don't Forget To Check Chain Wear & Alignment As Well!!!!
Good Luck!!!!
