slack as in you can move it without it going? there is a way to adjust it. On my '06 it is right there, it looks like it can be turned. Just turn that to the desired slack. it is on the wires right next to the brake.
(sorry thats the best that I can describe it.)
well hmm i think some call it play as well
like theres a lil gap between whn i engage the throttle
like no throttle...pass the lil gap...thn the throttle engages
There is an adjustment barrel fairly close to throttle. Follow the cables from your throttle and you will see it. About 6 inches maybe....
Try what TMP said if it does not work...replace your cables this kind of thing falls under general maint. it happens all the time pads,cables,treds,etc~
Very limited adjustment on the cables without having to remove the tank! May have to play with the adjustments near the rack!:crazyloco
