06 636 running muffler out side of bike like a gixr but a lil longer the end of muffler is at passenger foot peg. Any 1 have a map or can tell me bout how much to richen it please
I should have a map soon but it won't be as short as your exhaust. Mines a little longer. Do you know the elevation you are at? Mine will be from a dyno using wide band o2 sensors
Also did you check out to see if they had a map for you to base off of? With out dyno or adding the wide band o2 it's anyone's best guess. You could also make it more rich and then go ride around and see how it feels. Then adj from there and it will get ya in the ballpark at least lol. It's around $250 to get it dyno tuned and that's for each cyl. Not bad if ya ask me. Then you know 100% ur bike is set
