I am removing my swing arm from my frame and need some help....the largest hex socket I have is a 19mm and the local parts stores dont sell anything bigger....what size do I need for the swingarm pivot shaft?
thanks
if its the same size at a zx14 front axle i used a spark plug socket turned arround backwards you know the side that you can put a wrench on...a napa one in 1/2 inch drive you can put a extension through it as it has no shoulder on the inside of the socket to hold a spark plug...
