I had to replace the left handcrank case cover/alt cover removal was easy and the installation was going fine (lil trouble with the new gasket) but when i installed the started idle gear and shaft i think i might have fouled up. i placed the gear in first and then placed the shaft on the cover and installed the cover. , i think that was a bad idea even though the cover went on fine. I started up the bike with some trouble took about 5 min to start, ran it for 5 min and then it started to die. I started to panic and shut the bike down. I felt the cover and only after 5 min it was HOT. Any chance i didnt chew up any teeth on the starter gear or am i fucked?:banghead
PS do turn signals have hazards b/c my turn signals won't turn off
ANY SUGGESTIONS WOULD BE VERY GRATEFUL!!!:runaway :runaway
