Lots of random parts laying around in my garage. Direct any questions you have here or via PM. I have a pretty broad knowledge of what parts will fit what models. PM or text me for shipping/total cost to you. I'll have to add a few bucks the farther away you live. PM offers if the prices don't suit you. Trying to unload and make a few dollars to get my bike back on the road (long story, please don't ask here and clutter the thread, thanks). Phone number is at the bottom. I ship via UPS.
00-02 ZX6R & 05-08 ZZR600 parts
--rear wheel, silver off of 06 ZZR600, comes with rotor and hub (no sprocket) $90
--OEM clutch lever $5
--OEM mirrors painted silver (no mounts, just stalks, mirrors, and boots) $25
--Upper triple tree, straight, has ignition and one key (ignition missing plug--I can separate if needed and adjust price) $50
--gas cap, ignition (no plug, pins exposed and can be put into another plug), and rear seat lock with one key (ignition still in upper tree, but can separate if need be) $50
--rear axle with adjusters $15
--OEM rear brake line $5
--passenger pegs and mounts $40
--swingarm, small scuff on left side $40
--tail fairing, grab handles deleted, primer gray $50
--subframe, straight $50
--front foot pegs $5
05/06 ZX6R parts
--one straight fork with 06 ZX6RR internals and cap (left one I believe), no leaks, minor scuffs $70
--one slightly bent fork (RR internals and cap), no leaks, minor scuffs, good cap $40
--636 internals, no caps left, make offer
--upper triple, no ignition, might be tweaked (I can check) $30
**I have pics of the forks standing side by side and they're slightly off from one another. I'll install into my straight trees in a few days to check how bad they really are. There are no leaks, caps look perfect, legs have regular wear. Involved in crash, yes, but left fork appears straight compared to my known straight replacements and rolling on a known straight surface.
07/08 ZX6R parts
--one straight outer fork tube, silver $50
--two sets of fork internals including caps $40
--both lower tubes and other outer tubes bent, make offer
***I bought these forks thinking they were straight but needed seals, but during disassembly I discovered they were bent with the exception of one outer tube, which is in great shape. Still disassembled.
--some sort of fender eliminator for those running side mounted exhaust $10
--ECU, I assume it works fine $70
--exhaust servo thingy $5
--passenger peg mounting plate, not sure which side $15
--regulator $10
--passenger seat latch $5
--passenger seat lock, no key $5
--lower shock linkage/knuckle $15
09-12 ZX6R part
--OEM hugger in good shape. I've read these can replace the gigantic ones on the 08-10 ZX10R ?? $20
PRICES ARE NEGOTIABLE, DON'T INCLUDE SHIPPING, BUT I AM MORE THAN WILLING TO WORK ON PRICES.
I HAVE NO PICTURES UP BECAUSE PHOTOBUCKET IS BLOCKED HERE AT WORK FOR SOME REASON. I DO HAVE PICS AVAILABLE. TEXT ME AT 757-477-2706
