I want to put the Spiegler tubular handlebar mount on my bike with maybe a two to three inch rise handlebar.
Has anyone done this?
Does anyone know of longer cables that will work on a ZX11D?
Does anyone know if Concours cables have the same interior free length?
I once rode with 2" high "Genmar style" risers and stock cables were OK. Was tight at full RH turn though but everything worked perfectly.
I wanted to look at Concours cables but never did it...
Concours /ZG cables will not work, ends differ completely at OEM carb holders
For FCR Keihins they would probably work in length with riser or bars
Wild card maybe zzr1200 but I don't know the lengths vs zx11
might email [email protected] and explain rise with OEM carbs
as they do custom builds
JY11, you may have missed my response to you in another topic. The Speigler kit includes a longer choke cable and all the other cables are re-routed according to the directions that are sent with the kit. Very straight forward.They also include a S/S upper brake line as well so everything that you need is in the kit. There is no need to be looking for longer cables and lines. I will post a couple of pics of my conversion in a bit. I just need to upload some shots to photobucket so I can transfer them here.
Jay
You're welcome. I think that even if you end up with something like the Genmars, routing the throttle cable through the right side frame opening is a good idea...
Good Luck
Jay
