I'm looking for old and useless (for you) throttle cables. Must be the pair of "push" and "pull" ones. If some of you have those lying around, I could give them a good home.
I only need the outer sleeves; you could simply cut the steel inner wire and then unplug the sleeves section from each other to ease up packaging (and to cheap down shipping cost). The cable unplugs at the threaded adjusters shown on RH ends.
The minimum I need are both steel RH bent sections and threaded adjusters. Let me know if you can help.
FYI, I need those to make my own longer cables. I already made them but there are too much friction inside those two bent sections I had here. Cables works OK but I prefer to tone down the friction.
If possible, I'm looking for cables off a ZZ-R1200. ZX11's will work but ZZR1200's will be younger and probably have longer remaining life...
THANKS!
"I think" I have some "zx11" buried in my piles
>> I DO have zzr1200 cables if you need some measurements
>> and "might" have a spare set with all those engines I bought
>> also I will Not remove the Storz stuff off my racer in storage
but I have another Storz set buried in my piles that I can measure
off of when I find the time to "dig" OR I have an LSL set to measure
they are 2 different things thou
FYI the racer has cables off a gpz1000rx "1986ish" to mate up to the
FCR's BUT they are the threaded type not the slip in like zx11 CVKD
for the "Bars"
