Having a issue where my left side switches are all out and so is my headlight. Are they all on the same fuse or a relay ? And if so where is it?
In the fuse box, there is a RED 10amp fuse number 8 for the headlight relays, and in the battery tray there is another fuse for the power to light the headlights, this is a Green 30amp fuse, in the battery tray there is also another green 30 amp fuse but this is for the main electrical system and is hidden under the starter solenoid cover, so don't get confused.
When you have the system back together and select high beam if the high beam indication comes on the fuse in the fuse box is ok.
Discussion Starter #3
Thanks. Figured out when I was changing the spark plugs I must not have connected one of the plugs tightly. It came loose. What a pain in the ass spark plugs are
