The Kawasaki oil filter, Kawasaki Part Number 16097-0002, can be found cheaper at local auto stores.
The Normal Size is the same length as the stock oil filter, while the extended size is an inch longer allowing better filtration.
We have done the research, and it's the exact same as:
Normal Size - Bosch 3300
Extended Size - Bosch 3323
And if you dont mind spending a few more dollars for a better oil filter, the next ones you can goto are:
Normal Size - Mobil1 M1-108
Extended Size - Mobil1 M1-110
At quick glance, this oil filter is used on the 2005/2006 ZX-6R/6RR and the 2006 ZX-10R. I havent looked at other Kawasaki motorcycle applications, but as long as your Kawi takes the oil filter that is part number 16097-0002, then this will work perfect, give you a better oil filter, and save you the money the stealership charges for one of these.
