Here is what Kawi has listed on their own website as performance accessories for the 2006 ZX-10R:
Racing Camshaft*
•310 Degree Duration
• 9.7mm Lift
• Use with standard springs and exhaust cam
• These items are intended for closed-course competition use only
• Alteration of emissions-related components can constitute violation of federal and/or state laws. Substantial fines and penalties can result if used for other than closed-course competition use
• Use of unauthorized components and use of a vehicle in competition can affect a vehicle’s warranty coverage
• Kawasaki Accessories used in competition are not covered by any warranty and are not returnable
• Quantities may be limited and replacement parts may not be available
Price $84.66
Clutch Plate (Judder Spring)*
• Replace 13089-0003 in clutch stack
• Offers 50% stronger damper than stock
Price $118.52
WATER PIPE
• Analog Tachometer with Digital Temperature Gauge
• Requires each of the following
• ZX6R/RR
• Tachometer 25031-1142 (1)
• Meter bracket 11053-1749 (1)
• Meter pad 92161-0053 (1)
• Collar 92152-0058 (3)
• Rivet 92039-1231 (3)
• Bolt 130L0625 (2)
• Nut 92015-1233 (2)
• Collar 92015-1074 (2)
• Temp sensor 21176-1099 (1)
• Ground wire 26011-0071 (1)
• Lead Wire 26011-1779 (1)
• Racing main harness 26031-0325 (1)
• ZX10R
• Meter bracket 11053-1673 (1)
• Cowl bracket L 11053-1747
• Cowl bracket R 11053-1748
• Meter pad 92161-0098 (1)
• Bolt 130L0618 (2)
• Racing main harness 26031-0328 (1) OR Harness adapter 26031-0307 (1)
• Shift Lamp (optional) 23016-0006 (1)
Price $33.87
Analog Tachometer, Shift Light*
• ZX6R/RR
• Bolt 130L0625 (2)
• ZX10R
• Bolt 130L0618 (2)
Price $76.20
Analog Tachometer, Meter pad*
$8.80
