I have a 2001 ZX6R (J model); I was riding home one day and it just started to act like it was running out of fuel. I did know from mileage that I was running low on the main fuel valve so I switched it to RES to make it home on. Within 30 seconds of the switch to RES, It completely looses fuel flow and is only able to sputter a little further down the road. It would only sputter if I had the throttle at a certain spot. Too much throttle bogged it out as well as too little. Then it just came to a stop and never started again. I've been moving around quite a bit since and have had only limited time to work on it. The gas that was in it was only a month old or so. Since then I have:
-Replaced fuel filter
-Replaced fuel pump
-Cleaned fuel lines
-Cleaned fuel tap
-Cleaned little hose filter going into carb.
-Pulled Carb off and cleaned float chambers and needles. I had a lot of clear gelatin inside of float chambers which I can only relate to this sitting around and "Ethanol"
-While carb was off, pulled the top cover off and inspected piston. it was clean as a whistle.
-Replaced spark plugs
-Adjusted throttle and choke cables while I was in the mess
Now when trying to crank, it will only sputter a faint sign of life every so often but never anything that sounds too promising.
Stumped at the moment!!
Banned
Sounds like timing. Or the fuel pump relay quit. Check for voltage at the pump.
Hey thanks for the advice, I've been deployed for a little bit so i will be getting back to the problem. let u know how it works out
