j model build thread, finally started
7243 Views 168 Replies 10 Participants Last post by  Pyke13
3
So a few months ago i bought this
it came with this
White Product Green Tire Grass
Grass Font Event Recreation Carmine
Eyewear Sports equipment Headgear Grass Plant
now dont get excited, most of the panels are scrap or fiberglass
See less See more
  • Like
Reactions: 1
1 - 20 of 169 Posts
The front wheel is actually of my L model, its still got the same tyre on it just with less tread. I sold it to a orevious iwner of this bike about 5 or 6 years ago, its dated 2004 and was still being used until the bike was stolen and dumped.
  • Like
Reactions: 1
2
My original plan was a full restoration to standard but that's boring. So lightweight 900 J model it is.
those that have followed my L model build will know that depends on me ever getting both or any of my 900 engines up and running properly.
ive swapped the front forks for zx7r items, im in the process of fitting zx6r wheels. Ive bought genuine fairings and a replica single seat with 2 butt pads😀
Asphalt Road surface Grass Wood Landscape
Hood Automotive exterior Automotive design Synthetic rubber Tints and shades
See less See more
8
I spent ages restoring the fuel tank, some of you may have seen the video of it tied to a cement mixer on facebook😂
Liquid Fluid Ingredient Cuisine Gas
Gas Automotive wheel system Circle Auto part Metal
Motor vehicle Automotive design Tread Wheel Vehicle
Plant Flowerpot Houseplant Vehicle Boats and boating--Equipment and supplies
Grass World Soccer ball Ball Sports equipment
Helmet Hood Green Sports gear Automotive design
Hood Automotive tire Motor vehicle Bumper Automotive exterior
Automotive tire Grass Plant Asphalt Gas
See less See more
This is going to be a cool build
  • Like
Reactions: 1
What kind of exhaust is that?
Its a full micron system, 62mm link pipe. Think its called a micron 2000E but unsure on that.
  • Like
Reactions: 1
Automotive tire Water Purple Road surface Motor vehicle
the inside of the exhaust isnt as big as the outside, im going to strip and repack the exhaust as its an empty can. I will probably use the carbon fibre sleeve i have. Ive not fully decided that yet
See less See more
Automotive tire Light Motor vehicle Black Wheel
aprillia rsv rear calliper and hanger, bolt thru the bobbin bracket will hold it in place but needs to be spun round to bleed. Took a bit of work as i needed to “buff” the calliper to get clearance. 400g light weight rear disc, ive got titanium bolts in the post. There will be a few titanium bolts on this bike but nothing like 2fats build.
See less See more
Just noticed from the picture ive put the wrong spacer on the end of the axle. Away to change it now before i forget
2
The last owner liked to get there moneys worth out of things
Plant Grass Terrestrial animal Foot Human leg
Tire Wheel Automotive tire Motor vehicle Alloy wheel
I havent got as far as looking at the front sprocket yet
See less See more
The last owner liked to get there moneys worth out of things View attachment 22460
View attachment 22461 I havent got as far as looking at the front sprocket yet
I predict a similar condition
The chain was so bad i had to cut it off with a grinder just to be able to push the bike.
i guess your prediction will be fairly accurate
Trip computer Speedometer Odometer Motor vehicle Gauge
gps speedo one of china’s finest, even lights up pale red. Takes a minute or so to lock onto a gps signal but seems to read a true speed going by the gps speedo app on my phone. Tested it in the van
See less See more
That's cute! What's wrong with the speedo on the se7ens?
Nothings wrong with it but ive fitted zx6r wheels, so ive lost the speedo drive and didnt want to go for a koso type dash. This was the closest looking to the original i could find.
that makes sense
Should the rear wheel sit centred in the swingarm or is it offset?
2
Hood Motor vehicle Automotive design Azure Automotive lighting
Anyone know if these are genuine bump pads?
i know the brackets arent and ones been recovered
See less See more
1 - 20 of 169 Posts
