1 - 17 of 17 Posts
I have a 06 ZZR14(Norway) and i want to fit Yoshimura R77 on it but they only fitt for 08+
I bought a manifoild cheap on ebay thats suposed to come from a 08 ZX14 us version.
But i am confused since the (euro versions) 06/07 only have cat`s in the can`s and 08+ hav in the can`s and the manifoild. The 08+(euro) if i am corect has a O2 sensor, which i cant see on the ons i bought.
Hers a link to my garage on a Norwegian site wher you can see the manifoild.
http://www.bike.no/project/view.php?id=5834
Quinton Phuckin Tarantino
Ok so what exactly are you asking ? The picture I saw was an 08 + us version with no 02 sensor in it . I guess I am confused .
Discussion Starter #3
Sorry i was in a rush when i wrote it.
what i ment to ask is if the manifoild i linked to is from a 08+.
the manifoild that i have bought is from a us version zx14.
The problem i have is that the yoshimura r77 slip on only fits on 08+ zx14.
and i am confused becouse the europen version the 06 dos not have a 02 sensor but the 08+ has. And the 06 dosent have a cat in the manifoild but the 08+ have.
The manifoild i linked to dosnot have the O2 sensor but it have the cats(or it looks like it have).
Does the us version of zx14 08 have a O2 sensor?
senior member
06/07 has the cats in the mufflers and none in the collector (end of the manifold).
The 08+ has the cats in the muffler and one in the collector.
You would have been better off to get the R-77's and header for an 06/07.
If you don't have an o2 sensor on your bike, just break out the catalyst material in the collector of the header and have the o2 sensor hole welded closed.
Discussion Starter #5
My bike is a 06, the r77 only fits 08 and later.
If you see the link i posted you will see what i bought.
senior member
Ok,
so, you have an 06 and bought mufflers that only fit 08+.
Now you're stuck. You bought the wrong stuff. :dunno
Soooooo, where do you go from here?
You can either sell everything you bought, keep the header that came with your bike and get mufflers that fit the 06/07,
or, do what I suggested in the last line of my last post.
:dunno
If you have an '08 header, the R-77s will work. If not, you will have to sleeve the midpipe inlet down a bit. The '08-and-up 3-cat setup has an outlet diameter of 53mm while the older 2-cat pipes (no cat in the collector) is 50 mm.
Discussion Starter #8
No no no. Jesus i suck at explainig. Forgiv me i am from norwegian. I try one more time.
The manifoild part that connects to the enginblock is exactly the same. So if i buy a full exhaust system it dosent matter if its a 06 or 08 and later models.
its the "y" split that is the difrence from 06/07 and 08+.
senior member
06/07 didn't have the 3rd cat in the header.
When they added it in 08, the header collector was bigger, to fit the cat
and the outlets for the mid pipes got bigger.
that's why they specify 06/07 or 08+.
So, what exactly do you have?
You have an 06,
you bought 08+ mufflers
and want to know if you need the 08 header to make the mufflers fit?
the answer is yes.
But the 08 header has a cat in it.
If it has a hole for an o2 sensor, you can just weld it closed.
I don't think your bike would have an o2 sensor.
But, you still have the cat in there.
You might want to get that out of there.
I think the simplest solution is to sell the R-77s and get mufflers that will just bolt right to the 06 header you have.
Or, maybe you can have a muffler shop put cuts in the end of the mid pipes and compress them, so they fit in your 06 header.
I'm out of ideas :dunno
Discussion Starter #10
You have an 06,
the answer is yes.
No no no:banghead :lol
Do you see the link on my first post in this thred?
Click it and look. Is that a manifoild from a 06/07 or a 08+?
Thats my question
Discussion Starter #11
Sorry for my extremly bad explanation, i had started to drink and was geting ready for the night out :(
Discussion Starter #12
Thank you, the o/d on the one i bought is about 54mm, i dont have my bike her with me becous its stord for the winter so i cant compare.
I havent bought the slip ons becouse i wanted to make sure that the part i orded was from a 08 or newer.
senior member
06/07 looks like this,
The one in the link you posted is from an 09,
It has a cat in it,
senior member
And don't worry about the translation thing.
I can't understand half the jackoffs on this forum, half the time anyway.
And they're all FROM here.
Discussion Starter #15
Thank you:cheers
Then i can order the Yoshis R77.
The reson why i was confused is becouse at som other sites they said that it was from a 06/07 becouse ther wher no O2 sensor ther.
So tomorrow i am bona take out my hammer and a big flat screwdriver an remove the cat.
If any of you ever come to Norway, i will buy you a beer or two:crazyloco
1 - 17 of 17 Posts
