1 - 10 of 10 Posts
I just burnt out my clutches on my 02 zx6r and iam getting ready to put some new ones in. I was wondering if there is a way to identifiy which plate goes first ?
Banned
hey man remember the same way they came out the same way u put them back in, pay attention to every disc and also it won't be a bad idea to measure the thickness between all of them
how much space should there be in between? it doesnt make a difference to what friction you put on first?
Banned
your best bet is get your self a manual and do it right if you are going to be doing it your self
Don't pump the clutch while its apart. Before you put the springs back in, pull the clutch lever all the way and zip tie it to the bars.
thanks for all the response's i will hopefully be getting my clutches tuesday or so and i will use all the hints .
i got the clutches in just fine but its been like a month and come to find out i cracked the whole housing everything is warped about the housing. how did this manage to happen? i did have a lil problem of which way the rod that goes in between the clutches go. whether the spring goes before or after the seperator on the rod. so i was just wondering how could this have possible happened?
Banned
hey i have a brandnew set of ebc clutch springs for your bike, they are 10% stiffer than the oem 1's and they have a more positive feel and less missed shifts to, if your interested 15.00 Tyd for them and i have pay pal, great mod to do when u change your clutches bc over time your springs will weaken, let me no
Banned
let me no
1 - 10 of 10 Posts
