I have a 2007 Kawasaki ninja 500ex.
Here are the problems I'm having and can't figure it out.
I put new Ignition Switch Assembly,starter and the Starter Solenoid Relay and a new battery. And I dont have power to my ignition switch. Fuse are all good. I can run a jumper from my postive on battery to the ignition switch and have power that way and lights work. The min I pull it off then no power.
2. Is when I hit the start button the starter only turns the motor over 1 or a 1/2 turn.
3. There is coolant leaking from them two side hole between the fins on the head.
4. I put new clutch plates in. And cant fig out how to get the bolt right because it spins the clutch.
Any help would be greatly appreciated and thank you. I just hope I'm not f***ed
First if you have a wire not feeding power to the switch. It sounds like you have a broken wire between the battery and the switch. Normally I would check the harness near the triple trees. That's where the harness gets the most movement and the most likely to break a wire. I would fix that problem before anything else.
