1 - 10 of 10 Posts
My idle adjuster cable came out :eek:hno and i don't know where it connects to. If anyone knows or has had this problem please help me out.
Thanks!
You're gonna have to pull the carbs off :banghead , then you'll see where it goes by where the throttle cable goes in.
See ya
Chris
dont pull your carbs yet, happened to me once and i screwed it back in without pulling them. Just take your tank off, and it screws in right in the midle off the 4 carbs, check closely and you should be able to see where it goes.
There IS a spring and a little washer that WILL fall off when the adjuster is removed!
See ya
Chris
Discussion Starter · #10 ·
Yes, the spring and washer did fall off. So basically I should be looking between the 4 carbs for re-installing the idle adjuster cable, right? Any pictures, if any, would be very helpful.
Thank you all.
1 - 10 of 10 Posts
