I have the factory manual ("Manual") and a '06 ZX-14; I want to do a valve adjustment.
1. Manual page 22.2 tells us that when we remove the crankshaft sensor cover we find the crankshaft timing mark on what appears to be a toothed wheel. We align the wheel's TDC (top dead center) timing mark to the timing mark on the case (9:00 clock).
First question: I assume I remove the spark plugs and turn the rear wheel in a higher gear, in order to rotate the timing wheel. Do I rotate the toothed wheel clock wise or counter clock wise to align the marks?
2. Manual page 2-23 tells us to position #1 piston TDC, at the end of its compression stroke, then proceed to the manual's stated procedure to measure clearance.
Manual Page 2-23 also tells us to position #4 piston TDC at the end of its compression stroke, then proceed to the manual's stated procedure to measure clearance.
Second Question: Since foregoing item 1 states only one procedure to align the marks to set TDC for both pistons #1 and #4, what is the procedure for setting TDC separately for either #1 or #4, so the camshaft is in the correct position?
To keep it tight, only the guys who have done this on a ZX-14 should respond.
