About how much does five gallons of gas weigh? After the dry weight, how much weight is added to make it wet - including the gas in the tank, oil, coolant, and any of the fluids that have to go into a bike??
Gasoline weighs just under six pounds per gallon. In aviation, six pounds is used to calculate loading the aircraft. Oils are generally about the same weight.beansbaxter said:About how much does five gallons of gas weigh? After the dry weight, how much weight is added to make it wet - including the gas in the tank, oil, coolant, and any of the fluids that have to go into a bike??
