The bearings from lower triple on 91-95 7? I tryed prying em out, and only the bearings came out, how do you remove the whole piece?
A press with a bearing spreader. Since you're replacing them just go ahead and destroy the old one any way you can either with pry bars or a cut-off wheel.
To re-install, a trick way is with a pipe just larger than the stem that can sit flush on the inner bearing. And tap away with a hammer or use a press.
Josh
Thanks. I got it off with a little heat, screwdriver and hammer. Waiting on zx10 triple and zx7 bearings to come in so i can tackle the next step.
Banned
Are the 10r forks different than the 7 forks other than caliper mounts?
