ok, so heres the deal, im just bought a 1999 Kawasaki Ninka ZX-7R. This is my second street bike, the first being a 1998 Honda CBR 600. The first couple things i noticed about this bike is that it is heavy, but it seems very planted. Also how do you know if a bike is true, that is if the bike is straight. I heard that you just get up to speed and let go of the bars and if it doesnt veer right or left then its straight. Is this a good method?
No ....... you need some straight bars placed down either side of the bike .... if its not true there will be a different sized gap on one side at the rear.
As above or use a string line to check wheel alignment.
Any bike manual should describe the procedure.
Also check rear wheel adjustment marks as a visual aid.
Have you any reason to suspect that it is out i.e. is there any evidence of crash damage/repair?
not really any evidence of a big crash, frame looks fine, just you know worried about the new bike. When i drive and let go of the wheel it veers to the left, none of the other bikes that i've had have veered, they usually just track straight.
Also, check your adjusters on your real wheel. Being slightly out on one side will cause you to drift a little to one side.
