how can i tell if my zx6r f frame is bent? i have recently slid my bike into the rear of a car at around 30 mph fairing cracked in 2 places and my front wheel has moved backwards, i can't see an visual bends in the forks etc.
Since a frame is supposed to be pretty much symmetrical find a spot at the front of the frame and measure from there to a certain point on one side.....then do the same thing to the same spot on the other and if it is the same then its straight. And just do this at different points until your satisfied.
Remove the parts from the frame and take the frame to a tool and die shop. Ask them to check it with a run out gauge. It will probably cost you 10-20 bucks.
