I am getting a new black 07 zx-6r very soon here, and I think those superwhite type headlights would look bad ass on it. Not only that but it seems like it would help with seeing at night and having other cars see you better. From some research I see that there is an expensive kind that requires a bit of assembly on headlights, and another type that is just a normal bulb you switch in that simulates that Mercedes HID white headlight look. Any of you put these on your bikes? If so, which kind and does it work well/look good? Thoughts? :smile
Thanks!
run superwhite hiper bulbs H7 in slimer (bike dat is). though i don't get out much at night. during the times that i get back under night. the superwhites are white and illuminate a larger space then the stocks.
hiper white bulbs
stock bulbs
not the greatests pics. just want to point out the illumination on the hiper whites.
hope that helps on the bulbs.
