1 - 8 of 8 Posts
i have a 1993 zx11 that is leaking oil and its only at the bottom of this hose that comes out of oil pan going up been trying to figure out if it is hose or something else.i really could use some help on the technaical name of hose so i can order it and hoping for some advice on what else it could be that is making it leak i have layed the bike down by mistakes due to dumb drivers
A Photo or 2 would help but is sounds like an Oil Cooler Pipe.
Pic is definitely needed. Parts fiche for the oil pan doesn't have it listed. So it's labeled under something else. @Blainethemono do you have any idea what this hose is?
clean the entire area very well then run the motor to locate the exact spot of the leak
  • Like
Reactions: KevA
Been trying to track down one myself, & I think I narrowed it down to the Counter sprocket seal.
Second question, 1993 is the year there were C and D models, do you know which one?
Not familiar with C models but the D model has two hoses that go to the oil cooler and the end of one is toward the front and doubled up on a third hose that goes to the bottom of the pan. As suggested above, clean thoroughly and check. They are all banjo bolts so crush washers should be easy to replace. Also, the leak could be the oil cooler and running down the hose?
Organism Rectangle Slope Line Font
1 - 8 of 8 Posts
