So I've managed to get the exhaust on and mounted everything for the eliminator kit, but I can't figure out exactly what I'm supposed to do with the blinker and taillight wires with the given wire harness and parts. I'm not positive which connectors are what, I'm guessing on these photos. BUT...I'm sure you guys can help me out....thanks in advance!
From what I can see, and slightly remember from my install, the tail/brake light plugs right into the harness along with the plate lights/light bolts. Now, for the blinkers, you're gonna have to either use the quick splice or actually cut the wires and use the butt connectors or solder. Personally, I cut the wires and spliced everything in for a safer cleaner look. For the servo, either leave the servo in with the cables out like I did, or get a servo eliminator. It seems hard, but if you have basic wiring skills, it's easy. Good luck and hope this helped some.
