My girlfriend has an 01 ninja 250 and all of the sudden the headlight, tail light, and marker lights quit working. The turn signals and the break light are still working though. Ive checked the fuse in the box and all of the connections (I think) and cant seem to find the problem. I found the relay for the turn signals but is there one for these lights that I haven' found yet?
Any help would be great...
Go back to the main fuse box. Chase those wires out of the fuse holder and work those colors from that fuse box out.
Take a pair of needle nose or a paper clip and cross the fuse holders together and bypass the fuse just to make sure the fuse might visually look good but hidden is the connection. Then find the tail or head light wires going to a junction box and there is some wire not connected that caused the failure. There are way too many lights out that points to a junction box connection is out of it's socket.
Thanks for the help! Ill try that 2moro and see if I have any luck. Ill keep u posted... :banghead
