1 - 12 of 12 Posts
Need Headlight info. My headlights stopped working, running light operational. Check fuse box on top of tank, all looks good. Bulbs look fine. Anyone have any idea what it might be? I am not much of a motorcycle guru. I like to troubleshoot before I take it to the shop and spent $65.00 a hour. Thank you.
Check the wiring, maybe there's a short, a cut or maybe if you have aftermarket blinkers they may have some sort of interference.
Check you headlight high and low beam switch... Sometimes mine catchs between high and low not making contacts thus headlights are out...
Do you have a multi meter to check to make sure you're getting voltage the lights? Ohm the lights out to make sure they aren't blown.
Thanxx everyone for your help. I have check the headligh bulbs, there are working. Check fuse and high and low beam switch. I am getting juice from the fuse box, but no juice to the lights. I think it time to put it back together and take it to the shop. Just wanted to say Thanxx to everyone who gave there suggestions.
I just may be thinking out loud but for some reason I believe there arer a couple fuses down by battery, for some reason I think not 100% sure one of them may be headlight related but check manual to be sure..
I don't know what you're riding, but did you check schematics for your bike. Did you check to ensure that there isn't another fuse related to your headlights in the fuse box under the seat?
Hate to see you pay shop rates for something like that.
Head Light Relays Part #27002-1086 Located On The Bracket Under The Tack....it Has Two
swoosh is right... I have 1992 zx-7r and it has a headlight relay inside the fuse box. this is what makes your lights come on after you hit the starter. you can always run a separate circut for your lights with a switch. good luck. mine has been giving me tons of problems.
1 - 12 of 12 Posts
