Help!
My headlights are no longer working after a trackday. I pulled the fuses and re-installed them when I got back and now my headlights aren't working. Neither the low beam or the high beam. I swapped the junction box and relays from my other 636 same problem. I pulled the fairings and checked all the connectors and still nothing. I've yet to start testing voltages.
I'm in a pinch and have to have the bike to ride tomorrow to work due to a car problem.
Any ideas?
John
well, as dumb as this might sound, did you check the fuse you were using and make sure you didn't blow it somehow?
Thanks for the ideas guys. I ended up tracing it out with my voltage tested and found a bad crimp in one of the connectors. It had been crimped too tight from the factory and it looks like it vibrated enough to break off inside the connector. It was a pain but I used my handy little tester light and found it. Nothing a new crimp and solder couldn't fix. Good as new. AND, I actually made it to work!
John
