1 - 8 of 8 Posts
What tyres are the GTR's coming out with ? Are there different makes of tyres in different countries ? Have seen Bridgestone on Australian models !
1400GTR Tires
Model Name: 1400GTR (ML)
Marketing Code: ZG1400A8F
Front Tire: 120/70ZR17M/C (58W)
Rear Tire: 190/50ZR17M/C (73W)
OEM Tires: BRIDGESTONE BTTTLAX BT-021 RADIAL SPORT&TOURING
CATEGORY/ ON ROAD //JAPANESE//:
http://mc.bridgestone.co.jp/jp/products/category/onroad.html
ON ROAD/ BT-21 RADIAL //JAPANESE//:
http://mc.bridgestone.co.jp/jp/products/battlax/bt021.html
OEM/ KAWASAKI //JAPANESE//:
http://mc.bridgestone.co.jp/jp/products/machine/kawasaki.pdf
Basic Information of Motorcycle Tire //ENGLISH//:
http://mc.bridgestone.co.jp/pdf/mcintroe.pdf
Reference price of a certain shop
120/70ZR17M/C (58W): ¥16,360 (ICT) ⇒ about US$138
190/50ZR17M/C (73W): ¥24,640 (ICT) ⇒ about US$208
☆ICT: Including Consumption Tax
I wish the 1400GTR would be equipped with the “Tire Temperature Sensors”. :rolleyes
________________________________________
I love Kobe.                    Voyage to the future
If you are talking about tire temperature sensors, it has them. They are built into the pressure sensors and before displaying the tire pressure the EMC compensates for the temperature. Otherwise you would see tire presures of 50psi when hot. This is done so that you can see that if your tire pressure was 40psi when cold and the display shows 40psi after riding for a while that the pressure is normal.
I know the following.
Tyre Air Pressure Sensors System
*To warn riders of any tyre pressure irregularities, tyre pressure sensors are fitted as standard equipment (a first for
 a motorcycle).
*The system allows the rider to monitor tyre pressure while underway. When tyre pressure falls below 220 kPa, a low
 pressure warning is displayed. The ability to take into account temperature changes and display values recalculated
 for 20°C helps prevent false warnings when air expands as the tyres warm up.
 “Tyre Air Pressure Sensors System”, “2008 MODEL INFORMATION” (pdf-p15) Version: 7 Jun 2007
 Cf. “Tire Temperature Sensors” (#75), “Kawasaki GTR1400 and Cocours14” (p4)
Is the temperature in the tires displayed on the instruments? :smile
No you cannot see the temperature or true pressure. Only the corrected pressure is displayed.
Thank you. :smile
The temperature is not displayed on the instruments as expected.
It is said that the instruments indication is different depending on the model.
I wish the instruments could display it. :rolleyes
1 - 8 of 8 Posts
