1 - 11 of 11 Posts
Love my 84 ZX900 A1:
19993
Drove 25 miles home, what a blast! Will need some repairs, naturally.
Ordered a paper service manual, but would like to source a digital copy too.
Cheers!
Welcome
... Bike is lucky it didn't go to a butcher.
Bought from unfortunate owner who experienced oil leak from busted crankcase; surprised the entire bottom didn't blow out.
Tough to see in picture, but bolt or dowel pin floated around until it wedged between the gear on the
balancer assembly and the lower crankcase. The gear held firm, but the case gave way.
Still looking for the offending bolt or dowel pin, maybe came out with oil change?
20011
Can't tell from the picture. Does it need a new case?
Yes, yes it does. Suppose I could challenge my welder friend, but the crack runs through the threads for one of the external oil lines,
so by the time he fixes it, probably cost a fortune. Already bought used cases, in transit. Probably need other stuff, connecting rods, pistons, etc.
Odometer reads 16,666, but all the numbers are skewed towards 26,666, so I suspect neither number is correct.
I'd guess 45,000 by the wear and tear in engine, including piston pins stuck on the connecting rods.
Would like to buy entire good running engine (cue the laughter!) but I'm probably
10-15 years too late to find any good engines, so I might as well rebuild this one, eh?
Discussion Starter · #10 ·
I have found a piece of alternator tensioner broken off, common failure.
It looked okay on disassembly, but I'll double-check. I don't yet understand
the operation of that tensioner, but is the Tensioner Tamer worth it?
Here's the odometer, hokey eh?
20034
I would be tempted to buy another engine, and rebuild that one, but if high mileage it would probably have similar problems.
1 - 11 of 11 Posts
