1 - 9 of 9 Posts
Hey all I hope you're all happy and healthy. My bike starts up and has always made a "supercharger" whine at all revs. Comes from the crankcase... I have a video, can anyone possibly begin to point me and my mechanic in the right direction? He hasn't started diagnosis but just reading up on similar issues online, does this sound like a balance shaft?
Video here
Thank you
Discussion Starter #2
Pretty desperate...
I also just read this which is making me pissed off and sweating. From Z1 Forums.
17801
I JUST DID THE STARTER CLUTCH with a fresh one and a clean proper install!
Are there any insights at all fellas?
This sounds like your balance shaft is way to tight.
Start her up till warm, loosen the bolt and release till its starts to rattle a bit.then back till it just stops rattling but not so much that its starts to whine.
Skickat från min moto g(7) via Tapatalk
And the starter clucth can make a whine when you press the button and the starter looses its engange(Kinda slips).
Often happen when they are worn and your engine is hotter than normal.
Discussion Starter #5
Oh hey! Good to hear from you again! I don't have to split the case for that, right? I can just access it by taking off the clutch cover right?
Thank you sir!
No you do this without removing anything.you see in the picture behind the banjofitting.release the bolt under.then use a flat screwdriver to adjust
Also the shaft seal on these tend to leak.
Discussion Starter #8
My friend, once again you have enlightened me to solutions I didn't even know existed! I will try this tomorrow first thing after work, and hopefully (if it turns out to be the solution) I will upload another vid.
Thanks again, you the real MVP!
1 - 9 of 9 Posts
